Jayco23FB
May 09, 2018Explorer
I built a water filter so I can take water from a lake or stream and make it safe. I use a 20 gallon tub, a standard RV water pump and a 1 micron filter. I filter the water and pump it into the fresh water tank via the 12 volt RV pump. I also use a multi stage filter system for the gray water tank so I can reuse that water for watering trees etc. The final filter is activated charcoal. Everything going into the gray tank is environmentally safe. We have never had the smell problem some talk about. We only use this when dry camping when it is permissible.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
