sau4u
Aug 17, 2014Explorer
jauguston wrote:
The connection and hose you have to suck antifreeze through your water system bypasses the water tank when you are putting antifreeze into your water lines. You can experiment and you will find that with a different valve setting that hose will direct its flow to your tank instead. I have a Water Works Utility Panel in my Sportscoach and I can do that procedure with it. I recently bought a 30 gallon water bladder from Amazon that I can put in the back of my Samurai and get water from a campground community water spigot. Saves having to move the RV after it is setup.
Jim
That's what I was thinking, sucking up through the winterize hose. I wasn't sure but suspected it would by pass the water tank when winterizing. I will try sucking up through the hose when the valves are set to fill the system, see what happens I guess. Thanks Jim.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
