sau4u
Aug 18, 2014Explorer
Dpopps wrote:
I have the same brand 5er. It's not that hard, you don't need any extra pumps.
In side the water panel is a hook up to winterize your camper. Your unit should have come with a 5ft hose that has a conector on it. Screw that hose into the winterize spot on the panel. Make sure the pump is on,stick the hose in your water jug, turn the vavles till you hear water flowing in your tank. The pump will suck 5 gallons of water pretty quick.
If you need a longer hose Get a splice connector or make a longer one from scratch. I have filled my fresh tank this way a few times and it works great.
I don't rember what valves need to be turned but you can hear when the water is flowing, plus you water jug will empty quickly.
This is exactly how I did mine and worked great. One question though. How hard on the pump do you think this is to be continually run long enough to fill up the trailer. As long as its sucking water and not run dry I don't think it should hurt the pump. But do these water pumps in the trailer have a tendancy to over heat or something with continuous use. Thanks guys.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
