2112 wrote:
I had air bags on a previous TV and found that if you don't carry a compressor you are stuck with a rough ride once you unhitch at the cg. If you do go with them drop the extra coin on the integrated compressor and gauge. It makes life easier. I installed timbrens on my last two TVs and have been pleased with them.
I have a cheapo 12v compressor from harbor freight, that goes to 150psi. think it cost me $20.
I bought an adapter for the trailer 7 pin outlet to cig lighter,
and use the compressor that way for the airbags. Also on my f350 there is power under the rear seat. (I used this to pump up my Trailiar triglide hitch a little).
I am planning on a more substantial compressor setup, Viair 10007.. 150 psi, 100% duty cycle. $400. and a couple air valves and a switch, I can adjust the airbags on the fly.
