Reddog1's avatar
Reddog1
Explorer II
10 years ago
Air Bags/Springs - Firestone, Air Lift or?
I am setting up my newly acquired '04 Dodge 3500 DRW 4WD Quad cab. I question that I need Air Bags, but they would be nice to maintain headlight adjustment and level the TC when camping.
I am considering one of these:
1 Outside frame mount Firestones These are suposed to be no drilling required, but I see four holes in the brackets, and have no holes in my truck frame. Must have a minimum 5 psi.
2 Partial under frame inside mount Firestones Must have a minimum 5 psi.
3 Direct under frame (between frame & axle) Air Lifts These have an internal jounce bumper, which allow for zero PSI without causing any harm.
I have the outside frame mounted style Firestones on my '96. On two occasions, I bent the frame brackets going over speed bumps too fast. I reinforced the frame brackets.
The Air Bags must not interfear with the installation of a B&W Turnover Ball Gooseneck Hitch or this mount style B&W Turnover Ball Gooseneck Hitch
I am a little partial toward the Air Lift due to its mounting and zero psi (jounce bumper) ability.
Positive or negative experiences are appreciated.
Wayne
