MFL
Apr 18, 2018Nomad II
I would check tire pressure, truck and trailer. You should not have sway issues with a FW. If you are towing nose-high, maybe a little movement, but still should not make you uncomfortable. You should not need air bags towing your empty weight you mentioned. If you load the trailer heavier, with pin much heavier, you may need support to level the load.
Jerry
Jerry
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 12, 2026
