adamis's avatar
adamis
Nomad II
4 years ago
Let's talk air bags...
My 1999 7.3 dually has airbags installed by the previous owner. I've generally not bothered to inflate them unless towing a trailer with my Bigfoot camper (4000lbs loaded). Today while driving on California's 101 near San Jose I was bouncing along from our overtaxed and under fixed roads.
While bouncing up and down I had an epiphany that perhaps a little bit of air might help the situation. Typically I've run between 30 to 60 psi in the bags if I'm towing a trailer with the camper. If I have just the camper I have usually left them empty or at 30psi unless I'm on twisty roads where I might bump it up to 90psi. That being said, it seems app subjective to me. Hard to tell if adding air I'm helped at all or if it was just the roar improving in the section I was then on.
So those of you that also have airbags, what type of truck and camper weight do you have and what PSI in the bags do you run? What is your measurement of ride improvement other then subjective "feels better"?
