allen8106's avatar
allen8106
First Cat Scale Weigh In
2018 GMC 3500 DRW
9,375 - GAWR - Rear
5,600 - GAWR - Front
13,025 - GVWR
4,619 - Max Cargo
2010 Jayco 31.5 RLDS 5th Wheel
8,900 - Advertised dry weight
2,120 - Advertised dry pin weight
2,500 - Advertised cargo capacity
11,400 - Advertised GVWR
Loaded for road trip.
Truck and Camper
5,040 - Steer Axle
6,820 - Drive Axle
8,302 - Trailer Axles
20,180 - Gross Weight
Truck Alone
5,040 - Steer Axle
4,060 - Drive Axle
2,760 - Pin Weight
11,080 - Camper Weight
-I found it interesting that the steer axle weight was the same with or without the 5ver hooked on.
-320 lbs under 5ver cargo capacity.
-Truck weight includes, driver, dog, generator, 5ver power cable, blue boy tote, tackle box, fishing poles and cooler.
-2,555 lbs under drive axle weight rating
  • -I found it interesting that the steer axle weight was the same with or without the 5ver hooked on.
    I always set my GN and 5th wheel trailer hitch(s) to where it doesn't affect the trucks front axle much if any.
    Your 4060 lb drive axle empty weight is one of the highest I've seen even on haulers websites. Is the 4060 lbs number as is from the factory or after you added your stuff in the truck.
