tim665214's avatar
tim665214
First extended trip with 5th wheel
2016 Jayco Eagle HT 29.5 BHDS. Approx 10K GVWR. Tow vehicle is 2016 Ford F250 6.7 Diesel Crew Cab lariat. Coming from North of Fort Fort Worth to San Antonio via 281. For anyone not familiar with this route this is right on the edge of Texas Hill country. So not flat, but not exactly mountain terrain either. It was me, my wife, 15 year old daugther and her friend as passengers.
I was really hoping to get close to 12 mpg, but overall I averaged right at 10 mpg. Does this seem about right. I also noticed that when I had cruise control on (65 mph) that on the steepest hills it would always shift down to 5th gear, and 2 times it shifted to 4th. My truck had no problem holding speed, but it just surprised me that it had to shift down like that. When I wasn't using cruise control, it never had to shift into 4th, but it still shifted into 5th quite often.
Is this what everyone else is noticing who has a similar setup?
  • Those hills on 281 can be long and the extended pull while not steep will cause your transmission to shift down. Eleven MPG is actually pretty good but it might go up just a bit if your speed dropped a couple of MPH. We get our best mileage at 62-63 MPH. Just saying.
  • Going from Cleveland Ohio to Yellowstone west gate. Down to Moab then to Arizona ( painted desert ).
    Across Arizona through New Mexico, Texas , Oklahoma on I-40 back home to Cleveland.
    I averaged just under 13 miles per gallon.
    5er loaded is around 13,000 lbs.
    Truck GMC 3500 Denali 6.6 Diesel. Average speed about 63 MPH. I get my best mileage between 58 and 63 MPH.
  • If you want better mileage you will need to slow down on the hills. I would not be hoping for much more than 11 mpg.
  • 12mpg in your dreams. Just be glad diesel isn't $4.00 a gallon.
