Joeydrunk
Jan 29, 2016Explorer
2112 wrote:
JoeyDrunk - Let's try something. Want to be our guinea pig?
You say you're not there often. Can you go 3 or 4 days without dumping the black tank? A week?
Dump the tank, pour a generous amount Rid-X into the tank and leave it in there as long as you can before dumping and repeat. Use the tank as normal as you do this. Let's see if it dissolves your mound over time. Give it 3 weeks to see if it starts to clear things up.
No mess, no cramming a broom handle down the hole risking the chance of punching a hole in your tank, no endless hours of spraying a wand. Just pour and forget it.
Come back and let us know if this solved your problem.
On Edit: Rid-X works better in warm water. Are you in a location where it gets up to at least 60 degrees during the day?
Hey there, was kinda confused on ur directions. First u said to dump tank-but can't do that cuz it's clooged, then u said to pour ridx in and let sit then dump and repeat then see if that clears over time but wouldn't the first dump after its been sitting clear it. If it didon't I couldn't use as normal because it's totally full right now. But yeah, I have to take care of it this weekend, bought some ridx gonna let that sit for 24 hrs and use a broom handle if need be.
About Fifth Wheel Group
