Joeydrunk
Jan 29, 2016Explorer
Pipeman wrote:
Unique RV Digest-it. It says pour a large bottle of it in there and within 24 hours it will eat the pile. I use it regularly in my black tank. I've had the mound twice when water is not used enough. Water is your friend. It's not fun trying to get rid of the mound and the advice to wear a face mask if using a wand is to be well taken. Good luck. You aren't the first and you won't be the last.
That's what I got was the digest it. So do u think if it's totally full of solI'd waste a gallon for 24 hrs will do the trick. Should I use a broom handle as well, should I add as much water as possible also? What about after it clears, should I save some to use weekly
About Fifth Wheel Group
