dedmiston
Feb 13, 2018Moderator
Welcome to the forum and welcome to the Toy Hauler family.
I owned a WW FS2600 for 12 years and we absolutely loved it. Not that it didn't have it's problems (because it really did!), but we focused on the good times and not the frustrations. (You can read the WW Repairs thread to see parts of our journey.)
Good questions. You'll get an assortment of answers, so here are my opinions.
1. Yes. We typically bring our RV home from storage and turn on the fridge, and then we load the food the next day after it has fully cooled down. You can load it faster than that, but your food will warm up with the warm fridge before it all cools down again. Anything in the freezer will partially thaw and then re-freeze, so it's best to really let the fridge/freezer do their thing before you load them.
You'll hear different opinions about driving with the fridge on. We ALWAYS drive with ours on. Some folks say it's dangerous. Maybe do some Google searches to see if you can find stats to support one argument or the other.
A lot of people turn off their fridge before they pull into a gas station, because they're afraid the fridge's pilot light could ignite the gasoline vapors. I only pull up to the diesel islands, so I don't have a strong opinion about this. We never turn ours off.
2. Haha. You'll have to figure this out yourself. It depends on how much you shower, how slowly you wash your dishes, your diet, etc. The weather is a factor too. Your temps probably don't get as high in SC as they do for us down here in So Cal. I wouldn't leave my tanks to set like that during the heat of the summer, but I might during the winter. Only time and experience will answer this for you.
3. Yes. Sort of. Since your WW was owned by a little old lady who only used it on Sundays, it probably has the stock Iota charger that WW installed. Those chargers are pretty bad. Your generator will charge your batteries, but very slowly. The Iota has a little RV-11 plug (phone-style plug) with a resistor loop. When you plug that in, it will bump up to a faster charge. Use this gently, because it's too strong of a charge to use all the time. You'll boil your batteries that way.
You should look into upgrading to a "smart" charger that will charge your batteries at varying levels until it eventually shuts off when the batteries are fully charged. Better yet, look into an inverter/charger, so you can plug in your coffee maker and TV without running the gen all the time.
4. Yep. Lots. Keep reading forum posts. Also check out the Beginning RVing, General, and Travel Trailer forums. I also like the "RV Newbies" group on Facebook, but some of those discussions get kind of crazy.
5. Ask the previous owner if they ever had the recall work done. Assuming they didn't, there are outrigger arms that WW installed on some of the models. There's also a more major frame fix that you can see in the WW Repairs thread, but I don't think that applied to the FS2300. If the frame looks OK to you, then you should be good. Watch for the front cargo hatches and make sure they open/close freely. If they pinch, then you're in trouble. Also look for any separation in the bend of the nose in front.
Don't overload it and don't drive too crazy when you get off road. You should be good.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
