nayther
Feb 22, 2018Explorer
dedmiston wrote:
If you're more out of level than that, do everything the same, except in addition to using the legos or Anderson levelers, use a shovel to dig holes in front of the uphill tires. As you pull forward, your uphill side will fall into the holes and the downhill side will rise up onto the blocks.
Make sure you fill your holes in when you leave camp.
One thing I might add is to avoid raising the passenger side too much so you don't need another step to get in/out the door. If its that far off turn 180 so the door is "down".
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
