Dirtclods
Feb 25, 2018Explorer II
Just a suggestion to add when parked don't get it too leveled out leave the front a tad off the bubble or raised a bit for your crapper it well cut down on smells. Also note: there is a little void area from the toilet to the tank so if you happen to use adult wipes the can get trapped there. Just make sure your bowl is full of water when flushed or flush once for the paper products then another for your adult wipes. You my want to carry a long PVC pole or a grappler in case this happens .
Grappler https://www.grapplersinc.com/
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
