djousma
Nov 03, 2019Explorer
I hope someone with a MS gets on here to give you some good info. If you have never winterized, you might consider bringing it in to be done. Reason being, if not done right, and water freezes in the lines, you will be looking at potentially thousands of dollars of damage come spring.
That said, You most likely will have to use the onboard water pump to siphon the AF in through all the lines, and out all the fixtures. you don't want to pour AF into the fresh water tank if you can help it. If you have a dishwasher, or clothes washer, builtin ice maker, those all take additional steps to properly winterize.
Good luck, and hopefully someone with rig similar to yours will come along and give better information.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
