Veebyes
Nov 06, 2019Explorer II
I am about to winterise mine. Waiting for DW to finish need for water. We are on own tank. Drain hw by low point or anode removal. Switch to bypass so heater does not refill. Either use a 2 way valve on tank side of pump or disconnect & use a hose with connection to tank side of pump. Do the pink stuff suction thing each outlet hot & cold till pink flows. When all done turn the pump off at switch. Drain water tank at low point. This could take awhile if tank is fullish. Off you go to a dump & drain tanks completely. If like us the trailer will feel amazingly light on the way to storage with no liquids onboard.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
