RustyJC
Feb 08, 2016Explorer
If you're going to be traveling in temperatures below freezing, either (1) winterize the 5th wheel with RV anti-freeze (food grade propylene glycol), (2) blow out all the water lines with air and pour RV anti-freeze in the p-traps, or (3) plan on running the furnace while traveling to keep the interior and basement above freezing. Be sure your propane tanks are full before leaving. If you're going to be carrying anything in the holding tanks, be sure your tank heaters are turned on. All the above assumes that you will have 12VDC feeding your rig through pin #4 of your tow vehicle's 7-pin Pollak connector to keep the coach batteries from discharging.
Rusty
Rusty
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
