usnret's avatar
usnret
Fiver battery advice
The battery in my fifth wheel is over four years old. Should I consider replacing it based on its age? It has been used almost constantly during this time.
Thanks,
Jim
  • We have a 2004 fifth wheel, two batteries in it when I bought it used in 2010, still seem okay, but we are always plugged in while camping, and it is always plugged in at home, so the one time I used it boondocking I took a generator and when batteries got low from using lights, furnace and water pump, I just fired up generator, but I was out in the woods, so didn't bother anybody.
  • 9 years on our 2 interstate batt ,still holding a full charge,rig has 60000 miles on it.
  • Since you said battery (not batterIES), I assume you are typically in RV parks with power, don't sweat it. Worst case, you can plug in to get the slides in/out and pick up a battery when you get around to it.
    If the converter is keeping it fully charged and not over charged, the battery will last a long time.
  • There always exceptions based on personal opinions, experiences on batteries. There is no right or wrong views. Personally I replace batteries after 5 yrs. rather than wait until you are on the road RVing and have the battery go dead and then have to run around to find a battery replacement. I have the same rule for my tires, replace them after 5 yrs. for the same reasons. Waiting for a Good Sam tow truck to come out and change/replace a blow out is not my first choice.
  • Take the battery and have a load test done to it at an auto parts store. That will tell you how reliable it is. I keep tenders on mine and they last along time.
    Thanks,
    Jim
    Use it until it's done. Looks like you take good care of it to have it lasted 4 years so far. No need until you start noticing a capacity reduction. That will be the first sign.
  • I would not discard RV batteries based on age.
    I would get a hydrometer similar to below. Check the electrolyte condition.
    Hydrometer on Amazon
    If you've never used a hydrometer, this seems like a pretty good beginners guide to using one:
    Using a hydrometer to test battery
    Assuming that checks out, if I still had concerns about condition, I would pull the battery and have it load tested. Fully charge it first, using your coach converter, so you know you charged per your normal equipment.
    The only equipment I ever replace the battery on based on age, is my Ford 6.0 diesel. That is because it is known to be very sensitive to marginal battery voltage, and will blow the FICM even though it still starts the truck.
