- tahoemcExplorerAdd Dutchmen Denali to the list of **** gelcoat jobs, the front caps on their 5'rs were dark brown and had a whole slew of them back in 2012-13 that went bad within months of leaving the factory. Of course they didn't want to cover, even under warranty. I kicked, stammered, bitched up a storm, they finally agreed to pay 1/2 the cost of a white automotive paint job and supplied new decals.
Hope you find a good solution. - VeebyesExplorer IIIf they will pay for gel coat & painting is more, I'd pay the difference for painting.
- kohaiExplorer
sk734 wrote:
It's a Crusader. It is a 2015 and it is dark brown. I will probably paint it the tan color to match the side. Thanks for the reply
Prime Time is doing a 3 year warranty on the caps, if I remember correctly because of this problem. Contact PT and you may get them to pay for a local shop to redo it properly. - SabreCanuckExplorerI think if it was me doing it I would spring a little extra $$ and have them paint a stripe on instead of decals. Never have to worry again and cleaning/ waxing would be easier? I know OP already has th decals though.
- Paul_ClancyExplorer II
sk734 wrote:
Paul Clancy wrote:
Pay for paint and clear. Mine was fixed and looks great. 2014 crusader.
Did you paint it the same dark color?
Mine was done under warranty so yes same colour brown. $1500 if I had paid. Worth it. - JohnG3Explorer II
Veebyes wrote:
Wow! The mistake was made the day the gelcoat was sprayed on the mold. Boats should be any colour as long as they are a shade of white. Dark colours on a boat exposed to the sun just do not last.
Weight is not so much a concern so boats tend to have thicker gelcoats than RVs.
An awful lot of labour & material went into restoring that boat. Maybe more than it is worth. RVs can be restored. 300 grit pads are extreme. Better to start with something like 3M rubbing compound. It is available in different grades depending on oxidation.
There is no such thing as one step to fix it. Start with the coarse compound & repeat using a finer compound to eventually multiple coats of a pure wax or sealant. Lots of work. Keeping it looking good will take waxing at least once a year.
If it is really that bad I'd look into having it sanded & painted with automotive paint followed by a couple coats of clear coat. That will have it looking better than new gelcoat.
Our Montana (white gel coat) had decals peel. Removing the bad decals left shadows where the gel coat wasn't faded. I Had very good results with Rejuvenater and a 7 inch buffer polishing out the exposed area. Hard to see where old decals were. - B_O__PlentyExplorer IIPaint is the only lasting cure. Mine cost $1500.00 plus decals for the front. A couple years later the rear went that was $1050 plus decals. Looked so good when it was done that I got rid of it.
B.O. - BayleyExplorerI had the fading problem on my 2014 Northwood Arctic Fox. I rubbed and polished and spit shined and rubbed some more. No matter what I did it always faded again and kept getting worse. Save yourself the time, energy and frustration......have it painted and never look back!!!
- sk734ExplorerI have new decals. The question is whether you repaint and install the decals then clearcoat or must you paint then clearcoat and then apply decals? Basically can decals to be under clearcoat finish?
- eDUBzExplorerRepaint and clear coat - just like a car paint job, PPG - Valspar - Axalta - BASF all top brands.
About Fifth Wheel Group
