Hap_Hazard's avatar
Hap_Hazard
Flat Screen TV install question
As many of you know we have a 2008 FSC2800 weekend Warrior. I want to replace the analog TV with a new LED Flat screen unit. My TH uses a sidewall cabinet with a Lazy Susan style shelf to turn the TV to face the rear of the trailer for viewing. Currently it has a 19” TV installed on this shelf. I want to remove the Lazy Susan shelf and use a swing arm mount for the flat screen.
My question is simple, has anyone else done this in a similar cabinet set-up? How and where did you mount the swing arm and how large a TV were you able to fit in the space. Finally, how do you store the TV for travel (how is it positioned)? Any pictures would be greatly appreciated.
I know this has been discussed here before but I did check the archives without much success. Most were for MH or units that had central mounting cabinets.
Thanks in advance for your help,
Hap
  • I brought a mount from Amazon that has two brackets so I can slide it off easily for travel or move it from the garage/ living room to the bedroom .
    Mine did not have a cabinet for the TV just selves but it seems like it would work for you
    If you want can post a link when I get to my real PC instead of this tablet?
