Bull_Rider
Jul 17, 2014Explorer
I tried Flex Seal on a aluminum gutter corner three different times. Cleaned, wire brushed, then used lacquer thinner to prep the area. Didn't even slow down the water. Put on the applications next time, no luck. Then I cut some screen door nylon mesh and embedded that into the Flex Seal. Nope.
Finally took it all out, which was a job, and used Sikaflex, problem solved.
About Fifth Wheel Group
