joelc
Jan 17, 2023Nomad
Flickering Lights and Battery Charging fuse
Two item:
For those that have a Carriage Cameo (mine 2012) where is the fuse that goes to the battery. If this is blown the battery won't charge. I think I found it but am not sure.
2. I have a new AGM 12V gel battery in my 5er. With the converter/charger on the battery voltage drops under load (100AH at 850CCA). The Charger/converter will hold the lights for a short time, but also when the volts drop to 12.6 +- I get the flickering. I tested the unit and according to manufacture it is putting out the proper voltage with and without load.
All ground wires in the forward compartment seem tight and good. I have not checked the frame ground yet.
ANY RECOMMENDATIONS WHY VOLTAGE DROPS AND I CAN'T RUN 12v FOR EXTENDED PERIOD OF TIME?
