Hamops
Jun 21, 2013Explorer
donn0128 wrote:
Take the truck back to stock. Youll be much happier in the end.
I would second this comment. You'll have a far more stable rig because the C of G on both the truck and trailer will be lower. If after you lower your truck and you still have your trailer tilted high, raise the pin box up to the next set of mounting holes. By doing that you will lower the front of the trailer and have more clearance over the truck box rails. This will allow you to make tighter turns, but be careful that you don't bang the trailer into the truck cab. Replacement window glasses can be expensive.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
