CampingN_C_
Mar 17, 2020Explorer
Floor issue in 2018 Talon
Looking for some opinions on what would cause the floor to "crown" in the area directly in front of the slide out in our Talon.
Here's the backstory. We took it in because the slide was digging into the vinyl when closed. Jayco authorized a new floor as well as new rollers on the slide. When I picked it up I imediately noticed it still wasn't right. Slide was sitting on the floor and would've torn the new floor in one or two uses. I left it with them again and what was found was the floor has "crowned" up along the area under the slide (if the slide was in). With a 4ft level from the slide opening going across it's at least 3/8th off at 4ft. So the slide out geometry is correct but the floor is raised. It's not enough to feel when walking on it and it's not a "bubbled" effect.
Jayco has authorized the dealer some time to diagnose but as of today the dealer nor Jayco has a direct plan other then cutting into the floor, basically exploratory surgery. We've ruled out a bad frame outrigger and some other minor possibilities.
