clotusExplorerJun 16, 2016floor squeakIn my 2015 Sundance 245XLT I have a spot in the floor near the bed that squeaks when I step. The spot is right where the carpet meets the vinyl flooring on the carpet side. There is a little flex wh...Show More
GrumpyandGrandmExplorerJun 16, 2016Probably a seam in the plywood/chipboard flooring or it could be a loose staple/screw.
Related ContentSqueaking Floorbelt chirp/squeakSqueaking From MotorCan you name that sound (squeaking)?Mystery squeak found
