I installed a
Quickie Flush in my Class C and it was one of the best Mods I have done, and pretty simple.
I picked the Quickie Flush over the Tornado because of the high failure rate of the swivel part. A few of my friends had them fail and it leaves it useless in the tank.
The only thing that I changed is where the hose connects up with the flusher I put a
90 Degree Elbow in it to reduce the strain on the hose and make it closer to the tank.
![](http://i.imgur.com/ua7SyECl.jpg)
It looks like this when finished, with a quick disconnect on the end.
![](http://i.imgur.com/kewYuwdl.jpg)
Don't get discouraged if it leaks at the hose connections at first they are sometimes hard to get tight. Tightened mine up and have had no leaks anywhere.
Another suggestion is to make a test hole in a piece of wood or something and test fit the device to the hole. I found that the hole size suggested was much larger than needed
After watching
This Video at about 12:17, I will stick with my Quickie Flush,conclusion at the end of it is not so good for the Flush King.
Here in the West with our drought I cannot see filling the tank again with something like the Flush King and wasting all that water,with the Quickie Flush it is dump, rinse and go. Not a lot of wasted water by refilling the tank and getting poor results.
