Mikesr
Oct 01, 2017Explorer
Black Tank Flush Vacuum Breaker
Had a major water leak today while operating the black tank flush on our 2017 Outback 325BH. After turning the water off and cleaning up the majority of the mess I went in search of the source. Turns out it was the vacuum breaker under the bathroom sink. Checked the fitting for tightness and had D/W turn the water back on, still leaked. I decided to remove the vacuum breaker to get a better look at it. Seemed fine but I was suspicious of something clogging the breaker. Forget to mention when the leak was discovered we had a super strong odor of stink bugs in the bathroom. Well after shaking the vacuum breaker and flushing water through it in the kitchen sink low and behold a drowned stink bug emerged. Ok so tonight I’m doing my research and found this is common. The vacuum break still has a slight leak so tomorrow I’m calling the dealer and asking for a replacement. My biggest question is how did this stink bug get into the vacuum breaker? Could have it damaged the seat or internal seal of the breaker ? Should I replace with a brass vacuum breaker ?
Thanks for any suggestions.
