Black tank flush 'anti-siphon vacuum breaker backflow preventer' is OPEN to atmosphere around top cap.
Flush water comes in bottom, pushes a disc up which seals OPEN area and water then flows out thru side to the nozzle in tank.
When water supply is turned off, disc falls back down closing off bottom thus preventing backflow. When disc drops it also breaks any vacuum in line by exposing opening to atmosphere ---tank side
Too high of water pressure and it can leak out top
Disc not fully sealing off top area and it will leak out top
