Lantley
Mar 02, 2017Nomad
ChuckV1 wrote:
We have the Mor Ryde steps and love them, the bottom can be adjusted to either shorten or lengthen the angle of the steps.
As far having them down and putting a cooler near the door I'm 71 years old and have no problem, the way I look at it is you have to lift it up any to put get it into the door and all I do is come at the steps from the side an shove it into the door...
It takes me about 2 minutes to sweep off the steps with a broom and about 4 or 5 minutes to wipe them off if wet .... If your in that much of a hurry to pack up I feel sorry for you, my average is about 30 to 45 minutes from start to pulling out, so whats an extra 5 or even 10 minutes ...
Let's talk about that cooler and coming in from the side.
On the left side I have a slide out and extended door handle. On the right side is my door. My door does not open past 90 degrees and blocks access from the right.
Stepping around the stairs in the down position is not that easy with my rig.
In the end I prefer steps that stay outside. The added sweeping and wiping are a deal breaker for me.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
