jessica90
Jan 14, 2020Explorer
It's normal to have a slide topper introduced beneath the overhang of the RV if the canopy happens to be over the slide out. For whatever length of time that you have space for a rail to fit under the primary canopy rail this would be thoroughly fine. To select the right slide topper you have to quantify the width of your slide out including the rib that goes around the outside of the slide out. In the event that that measurement is somewhere in the range of 80 and 85-3/4 inches the Sol era 7.5' Slider (Slide-Topper) # LCV000163287 that you referenced would be the right size. This likewise accompanies the required overhang rail to introduce. I joined an introduce video for this pack for you to look at also.
About Fifth Wheel Group
