I'm just looking into possibly buying a small 5th trailer, under 25' in length. I know weight is a major consideration. Will a Ford 150 tow a small 5th wheel? if so, any recommendation on engi...
Most have enough engine to "tow" it but more importantly you need the payload rating and axles to "carry" it. You need enough payload to handle the loaded pin weight, hitch weight, gear and all passengers added to the truck. You will likely need the rare max tow, max payload package F150 to do it within the numbers.
