ricatic wrote:
BB_TX wrote:
ah64id wrote:
What if the 250/350 uses the same axle? It does, BTW.
According to Ford web site:
.............................................................F250....F350 SRW
Axle Shaft — Spline Minor Dia. (in.).....1.36.......1.50
...........— Spline Major Dia. (in.)............1.50.......1.57
...........— No. of Splines (Hub End)..........35.......37
So the axles are not the same.
BB...all Ford F250 and F350 SRW trucks are equipped with Sterling Axle Plant manufactured axle assemblies...These are assembled in the Sterling Heights Axle Plant nearby...and which has my BIL as the number two man in the entire building...my information comes directly from him...they are the same exact assemblies shipped to the Louisville Assembly Plant with no designation as to which of the SRW series trucks they may be mounted...
The larger axle diameter you mentioned only comes on the F350 DRW trucks which are equipped with the Dana manufactured axle assembly. This confusion continues even today because Ford has not fixed the mistake in the specification publishing...maybe some day Ford will fix the mistake...
Regards
Makes sense as we know its used on 250/350 SRW trucks.
