MFL
Mar 25, 2019Nomad II
Cummins12V98 wrote:
With the adapter you are simply throwing good money after bad!
Above is true. Some things to consider...Using an adapter raises hitch height. Depending on fit, can be a more movement/clunking. Do you really need a sliding hitch? A B&W 3300 for Ford (non-slider) fits the pucks directly, and is light wt...2 pieces 75 lbs/78 lbs. A direct fit slider is also available, but heavier.
If you save the $400, not buying adapter, sell the current hitch, you'll only be about $400 from a quality direct fit hitch. I know, it is easy to spend other peoples money, and if wanting to keep current hitch, it will work with one of the adapters.
Enjoy that new to you truck!
Jerry
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
