Itinerant1
Oct 23, 2017Explorer
Nothing wrong with the gas engine but you should think about 4.30 gears instead of 3.73s.
The F250 could do it but you will be adding stuff to beef up the ride depending on what packages are on the truck.
Look at the F350 in srw if the srw is a must. Once again depending on the packages ordered with the truck you still might want something to help with possible rear end sag.
A F350 dually gas with 4.30 gears has you covered all the way around.;)
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
