Swamp_Man
Sep 24, 2013Explorer
Ford Tow Command
I am having a problem with our 2005 F-250 diesel with the Ford Tow Command brake controller.  I have had the truck in the shop twice to have the dealer look at the system.  They told me that they can find nothing wrong with the system.  We went on a trip to Virginia and while on I-85, the truck dropping out of cruise control, the ABS brake light came on, and the trailer brakes went away.  Using the manual slider, I could apply the brakes but that was all.  I had rewired the trailer with #12 wires and put in an new weatherproof ez-connector.  The system worked fine until the truck had been running about eight hours.  Then suddenly, the truck drops out of crusie control, ABS lights, and the trailer brakes are gone.  Pulled into a rest stop, checked the trailer connection, it was good, and looked under the trailer to see if brake wires had been damaged.  Nothing.  Shut the truck off, started it again, the controller works, and no ABS light.  About thirty minutes later, same things again.  Have to use the manual slider to apply trailer brakes.  Get to campground, unhook, check fuses, wire connections, look under dash for anything loose, and find nothing.  This is the later model controller as the truck was made in later 2005.  Any ideas?
