Old-Biscuit
Jan 23, 2014Explorer III
NC Hauler wrote:fairhaven wrote:
Old-Buscuit I don't understand what point you are trying to make. Are you saying that my fiver is too much for my tow vehicle? Let's see. My truck axle (3.55) is rated to pull a fifth wheel with a max weight of 15,300 pounds. My coach, fully loaded and certified scale weighed (last trip to the ocean) was 13,982 lbs. I am a good 1300lbs under the max fifth wheel requirement. My trucks certified scale weight was well under the loaded max weight requirement for the F350. So, what is your point? Do I need a dually? I don't think so. Am I being unsafe? I don't think so. Could something weird happen and cause me problems? Sure. But something weird could just as easily happen to a dually. I say get what you want and are most comfortable with, and be sure to stay within allowable specs.
As stated earlier, you're not looking at the numbers that mean the most...Most of these "recommended 5er weights you can tow", are mostly "bogus".....IF you have a 15,300# 5er, you COULD have a pin weight of over 3,000#.....Now I don't know what the GVWR of your truck is, but if you weigh your truck, all set up and ready to go camping, full tank of fuel, family pets, gear whatever, 5er hitch, and get THAT weight...NOW add , (giving you the benefit of the doubt, a pin weight of 2800#, based on your 5er weighing 13,982#)...NOW what does your truck weigh? Have you exceeded the trucks GVWR? Not that it matters, because hardly anyone, ('cept for me and a handful of others on this forum), pay ANY attention at all to the trucks GVWR, most go straight for the rear axles weight rating. What is your rear axle weight rating? Odds are, if you hooked up to a 5er that the manufacturer says you can tow, you''ll go over your trucks GVWR and start cutting into it's RAWR...so how far can one cut into the RAWR before starting to wear out their truck, or losing some of their trucks built in safety features...I don't know... but understand that a number that a truck manufacturer has tossed out that states you can tow "X" amount of weight of a 5er is silly, there's more to the formula and pin weight has a big bearing on what truck one might need. Odds are, one will exceed their trucks GVWR before exceeding their trucks GCWR, but again, at what point, if you start cutting into your trucks rear axle weight is it possibly prematurely wearing out your truck.
That is all Old Biscuit was trying to say....Just because manufacturer states you can tow "up to a "X" amount of weight 5er...doesn't alway's mean that it is "necessarily so"...just some simple math and common sense can help one figure out what truck they need to "do the job" and/or "git er done" :)
X2
RAWR and/or Rear Tire MAX Load Rating will be reached/exceeded 'before' reaching that magical tow rating number.
Weighing the truck and trailer is the best way to find out what you have vs any guesstimates using published mfg. numbers.
Good for you taking it across the scales.......
So what are the complete numbers??
Trucks GVWR------trucks actual weight with & without trailer
Trucks F/R axle weight ratings------with & without trailer
Trailers axle weight-------pin weight
All those numbers are available from weigh ticket(s)
My SRW has a Tow Rating of 16,250#......Hahahaha
With 5vr at 13,830# I am at RAWR/Rear Tire Max Load Rating and just over trucks GVWR.....yet still 2420# 'under' that magical tow rating number.
That's my point.......simple reality and doing th math with real numbers.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
