NC_Hauler
Jan 24, 2014Explorer
Me Again wrote:NC Hauler wrote:Me Again wrote:JIMNLIN wrote:
You guys that have a pre '13 model 3500 SRW Dodge truck seems to forget Dodge only rates your SRW at 6200-6500 RAWR with a paltry 10100 GVWR vs fairhaven's F350 SRW with a 11500 GVWR and 7000 RAWR. Apples vs oranges in load carrying capacities.
The comment that the SRW rear axle will some how break or other scare comments is hilarious as usual.
The wheel or tires will go long before you break a rear axle on the Ford or Dodge or GM one ton SRW trucks when severally overloaded. So far no one has reported being over weight.
I did a little math with fairhaven's and jimnlin's numbers
7000-218=6782 Rear weight plus around 4500 on front axle is 11282 and he is under GVWR of 11500. Chris
Ok, I'm confused...which is normal for me, but IF he is putting 6,782# on his rear axle, ie, only 218# from the "weight rating" of the axle be it buffered or not...Isn't that quite a bit of weight on the rear axle? Isn't that getting really close to going OVER the rear axle weight rating? I don't know, but that just doesn't seem wise to me. I know the axle isn't going to break...I know that GVWR is a useless number, as attested to by almost everyone now a day's, BUT, coming within 218# of going over the RAWR, I would think, would be possibly prematurely wearing out bearings, or some of the suspension components, but I'm a numbers fool, can't help it..and I didn't see anywhere we were given the amount of weight put on the front axle, though, it may be less with so much weight in the back....Even I understand why most don't use GVWR, but using over 95% of ones rear axle weight rating, I would think would cause some alarm, whether OP is over his GVWR or not.
and we've (me/I), have gotten off topic, now addressing fairhaven and OP was emscopter and below is his post (start of this thread)...
"I have a 2009 F250 right now and we just purchased a 2012 40 foot Alpine fifth wheel. I am wondering if we should get a dually truck and if we should go with a Ford or Dodge. I have had real good luck with this Ford except we had to replace the transmission due to putting on a tuner which I was told made the transmission go out faster. My truck has 86,000 miles on it. We are looking at getting a fairly new used one. Any suggestions would greatly be appreciated.
So Jim, on the trailer tires we think LT's can be used at their max ratings and ST should have a buffer because of their inflated ratings. Now you are saying that LT on a truck should not be used near there max rating which is based on a 99 or 106 MPH speed rating. I would have not issue using a LT at normal freeway speeds at its max rating. This site is not full of rear tire failure reports on SRW TV! People for years have used GM 2500HD with tires rated to 3042 to haul very large trailers, and they are not all on the side of the road with failed rear tires.
When one tows with a duallie with 45-55 lbs inflation in the rear tires, what are tires rated for at that inflation? Chris
:hWasn't even talking about tires Chris, I was talking about the rear axle weight rating. Just the axle rating. I was going by fairhaven saying he was 218# under his rear axle weight rating. I don't think I said anything about the tires. All I was referring to was if his rear axle rating is 7,000# and he is within 218# of hitting that weight rating...I was saying I think that is REALLY close to exceeding the axles rating...I would be afraid I would wear out bearings or weaken the suspension, and/or rear axle if it is "weight rated" to 7,000# and there is 6,782# of weight on the rear axle.....
I even used my own analogy...My rear axle, and rear axle only is rated at 9,750#, I wouldn't think of putting 9,532# on that rear axle and tow through the mountains that I tow through, knowing I only have 218# of rear axle "weight rating" left...now I know there is a buffer in there, but all I was alluding to, (really not talking about tires), was loading one's rear axle that close to it's manufacturers recommended rating... I know we don't use GVWR, most use RAWR, but I just thought that coming within 218# of one's rear axle weight rating was really cutting it close to overloading one's truck...doesn't leave a lot of "room" for any more weight....That was it...Again, i know that tires figure in on axle carrying capacity...but I was talking about what the RAWR was and how close fairhaven was to going over it....I was more curious than anything else...I wouldn't load my truck that close to it's rear axle weight limit.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
