Me Again wrote:
JIMNLIN wrote:
You guys that have a pre '13 model 3500 SRW Dodge truck seems to forget Dodge only rates your SRW at 6200-6500 RAWR with a paltry 10100 GVWR vs fairhaven's F350 SRW with a 11500 GVWR and 7000 RAWR. Apples vs oranges in load carrying capacities.
The comment that the SRW rear axle will some how break or other scare comments is hilarious as usual.
The wheel or tires will go long before you break a rear axle on the Ford or Dodge or GM one ton SRW trucks when severally overloaded. So far no one has reported being over weight.
I did a little math with fairhaven's and jimnlin's numbers
7000-218=6782 Rear weight plus around 4500 on front axle is 11282 and he is under GVWR of 11500. Chris
Ok, I'm confused...which is normal for me, but IF he is putting 6,782# on his rear axle, ie, only 218# from the "weight rating" of the axle be it buffered or not...Isn't that quite a bit of weight on the rear axle? Isn't that getting really close to going OVER the rear axle weight rating? I don't know, but that just doesn't seem wise to me. I know the axle isn't going to break...I know that GVWR is a useless number, as attested to by almost everyone now a day's, BUT, coming within 218# of going over the RAWR, I would think, would be possibly prematurely wearing out bearings, or some of the suspension components, but I'm a numbers fool, can't help it..and I didn't see anywhere we were given the amount of weight put on the front axle, though, it may be less with so much weight in the back....Even I understand why most don't use GVWR, but using over 95% of ones rear axle weight rating, I would think would cause some alarm, whether OP is over his GVWR or not.
and we've (me/I), have gotten off topic, now addressing fairhaven and OP was emscopter and below is his post (start of this thread)...
"I have a 2009 F250 right now and we just purchased a 2012 40 foot Alpine fifth wheel. I am wondering if we should get a dually truck and if we should go with a Ford or Dodge. I have had real good luck with this Ford except we had to replace the transmission due to putting on a tuner which I was told made the transmission go out faster. My truck has 86,000 miles on it. We are looking at getting a fairly new used one. Any suggestions would greatly be appreciated.
