Cummins12V98
Nov 22, 2015Explorer III
momentum rv wrote:Cummins12V98 wrote:
Go to the scales you will have a real eve opener!!! Our 39TKSB3 factory scaled 18,0??# and truck and RV combined is 32,500#. Truck 10K RV 23K.
DRV is full of Barbara Streisand with their numbers!!!
At 23K what size axles are on that beast? Even with 5k on the truck you have 18k on the axles.
MorRyde IS axles. The axle weight is 17,500#. I know the IS is no problem with that weight and the GY H tires still have more capacity left at 4,800# per tire = 19,200#.
I am thinking about adding a third axle when I have the 2" riser added at the MorRyde factory. It would be a pretty simple add at that point since the axles have to be removed for the 2" riser.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
