rmalik1
Apr 06, 2015Explorer
racer4 wrote:
"Can someone explain what "hung walls" are?"
Download the Back To Basics brochure and look at page 5.
Cedar Creek
The fiberglass is thicker and does not use luan sheets for rigidity. It is NOT laminated.
16 on center walls - outside the gel coat is fasten w/ super strong adhesive and batt insulation is used between studs, on inside the wall board is applied. Built more like sticks and bricks house. Will not delam, inside wall board can be remove for easier repair of sections instead of full wall like laminated walls,outlets can and are placed in normal places within walls because of this type of construction.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
