wanderingbob
Dec 20, 2016Explorer II
Reason for floating roof is that the aluminum sheet and the steel beams will expand and shrink to different degrees . If they were screwed or riveted they would eventually wear the fastening holes larger and cause leaks . Not so on vertical sides . All fastenings that you add to roof sheet should not be mild steel or even aluminum ,only stainless or plastic ! IMHO
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
