barchetta1
Dec 10, 2016Explorer
coolmom42 wrote:
Put a space or 2 inside. They are cheap and abundant this time of year. Any WM or Dollar General will have them.
If you are not willing to do that for some reason, do the following:
Drain the water system and water heater.
Go to Walmart and get some RV antifreeze. I know you are not far from a WM in SC.
Pump the antifreeze through the water lines until they all run pink. Pour some in the traps and toilet.
No electric power at storage.
I need to clean the darn water tank.. I pulled drain out and something very disgusting came out. we just bought this unit and have had it out a few times but have not gotten around to that task.. we've always had water at the site..
So no way to pump water unless I want whatever is in there in the lines.. which I do not..
so just hoping for the best.. I just looked and it was in the 20's last night for nearly 8 hours.. ouch..
I did look at the drain plumbing and saw no leaks while I was there..
I would think if I were going to have an issue it would be where the water hose connects.. but who knows.. ugh.. I wont let this happen again.
About Fifth Wheel Group
