barchetta1
Dec 11, 2016Explorer
Dave and Sue wrote:I think I really screwed up
Probably,but maybe not.Do you have a walmart near by?Is so get some rv antifreeze there.Jumper cables to your battery if it's dead or low charged.You can make a adapter hose to pump from jugs to lines.If you need to clean out the tank you can do that in the spring.Run your furnace and pump and dump anti freeze in the drain.Not hard to do and can save many dollars in damage.If you don't know how to do these things,Google is your friend. Good luck.
I dont think my pump is going to self prime.. but I may give it a try. I think my only hope is that when I dumped my water heater and left the cap off that the lines drained. There is still dripping water coming out after two days.
Ive got to come up with a way to check for damage before leaving thursday.
About Fifth Wheel Group
