artman
Dec 11, 2016Explorer
RAS43 wrote:barchetta1 wrote:
Drains are no where long enough to get into a jug of anti freeze.. I need an adapter.. and why there are two I dont know.. they are right below the outdoor shower.. maybe they are just for the shower.. I dont know.
There should be 1 drain for the cold line and 1 for hot.
Like RAS43 said two drains but you don't need to get a jug of anti freeze close to them.
Might want to level the trailer also so these two drains are at a low point.
Most likely you have a valve that switches the pump from using the tank to a hose that goes nowhere.
Close all the faucets and drain vales.
Turn on the water heater bypass valve ( no reason to put anti freeze in it since you have drained it).
Put the hose in the jug and run the pump.
Run each faucet and drain until you see anti freeze.
About Fifth Wheel Group
