barchetta1's avatar
barchetta1
forgot to winterize and it went to 21 last night
I drained the water heater but I dont have any anti freeze and no way to blow out the system.
Supposed to go to 25 tonight.
We are going camping next week... thurs thru sunday.
What should I look for to try and avoid a problem? Parts I should try and order?
  • Fill wh back up. Turn it on. Let hw flow into lines every few hours. Keep rig heated as much as possible.
  • open low level drains, throw some RV antifreeee in your black tank, and down your sinks, shower, etc You should be fine as long as it doesn't stay below freezing level for a long period of time. If you are able you can put a portable heater in your rig and set it to 60 degrees or even cooler that will help as well.
