kyleartic's avatar
kyleartic
four season porch sliding door for toy hauler
I am looking to frame out the back of my toy hauler and put a 4 season house sliding door there. I was going to use treated wood with sill seal aginst the frame and use self taping screws to mount the frame to the RV. I would use plywood with waterproof paint and the inside use drywall with instalation between the studs so I can keep the back ramp down as a deck year round and still keep the heat in the winter and let in maximum amount of sun light.
Has anybody done this or heard of anybody doing this?
I know they make 3 season doors for RV but they are a bit more expensive and not 4 season.
The price point for this project is projected between $450-$500.
I have a 2013 Heartland Cyclone 3950
  • At the back of the hauler there should be a metal frame around the door, that should provide a fairly "movement free" zone. I would actually encourage the French door idea with a sliding/retractable screen door setup. The slider and all that glass bouncing around would worry me and you have almost the same problems with movement and settling. Also, if it was ever left unlocked during travel, the slider would slam side to side, likely with enough force to break things.
    Good luck either way!
  • The project would add a couple of hundred pounds to the weight of the RV which I am not to concerned about. I do want to paint my Cabinets a light grey with white and grey exotic granite and install a full size gas range and convert it to propane but that project got veto from the wife. So the only project I have been able to do is put laminate flooring in the bedroom and but a back splash behind the oven.
    Next project is to make a sliding pantry next to the fridge for the pots and pans and can goods.
  • dedmiston
    I was going to make it go as close to the ramp as possible.
    At the moment I do not have any toys we sold our 4 wheelers we are looking at full timing it again in it and I put carpet down in the toy hauler and we use it as the kids toy area/second living room. I just thought it would be cool to always have the porch as a porch and get a lot more sunlight in the back since it is minimum.
    i do have a motor cycle which would fit through the sliding door I would just build a ramp to get over the track or if I get 4 wheelers again I would take the doors on the track to put them in.
    I was thinking of doing French Doors but that is more costly and I would be concerned with movement and settling that they might not close properly.
  • Hi Kyle. Welcome to the forum.
    This should be an interesting project. I haven't heard of anyone doing this before. How much room do you expect to have between the ramp and the slider?
    How wide are your toys? Will you be able to get them through the slider door?
