Red-Rover
Dec 14, 2013Explorer
Frameless Windows?
Looking for a web site that describes "frameless windows" being touted as a plus in some RV's. Best I can determine is that they are double pane? What about opening mechanisms?
PawPaw_n_Gram wrote:Check Sydney's Cedar Creek, it has the frameless windows on the side of the slides but they slide open (so technically I guess the bottom of the window has a frame that shows), but they look nice. I hadn't seen that before.Atom Ant wrote:
Just a note: I have not seen them in the side of the slides. I suspect they don't slide well through the slide seal. Ours has dual pane standard sliding windows in the sides of the slides.
I ask an Open Range rep at an RV show about that - the possibility of catching on the slide seal is a concern.
Another thing on the slide is they never install the crank out windows - only slide up and down windows. Because certainly someone will try to move the slide in with a crank out window open.
