Macman83 wrote:
lincster wrote:
I always fill up at home.
I have enough truck to not worry about the extra weight.
If you are worried about 1000lbs, you don't have enough truck and you have bigger issues to be concerned with other than water weight.
You might take a look at my signature, I probably have a little more truck than you do.
My concern is my 2700lb. Useful load minus 1170lbs of motorcycles, minus 420lbs of generator/toy fuel, minus 100-200 lbs of food and gear, and after you add them up, I am pretty close to my gross weight. If I decide to add some batteries or other equipment, I will have to start limiting some weight and the easiest place to start is the water tank. The concensus seems to be 'take it with you' so I guess its time to load up everything and head to the scale.
Anytime u want to pull a 7% grade, let me know, pretty sure I will walk away from u. And I have plenty of truck for my hauler.
