Dirtclods
Sep 17, 2014Explorer II
Yamafan1 wrote:
I have a 2008 attitude z-gravity 23lfs. The fresh water holding tank outlet fitting has a crack on it and it looks as though the fitting is plastic welded into the tank. What is the best way to fix this without taking it to the dealer?
OK don't worry it's not that bad. I have an 2007 19"ft attitude. Mine did the same thing. If you plan on removing the tank yourself empty the tank empty first then disconnected your systems wires from the tank disconnected the other water line from your tank that feeds the other one. Theres two rails that hold you tank in place you will need to remove this all should take you about an hour or so you'll spend more time finding the tools rather then doing the job itself. I contacted Mike Thompson’s RV Super Store in Fountain Valley 714 593-2162 they referred me to Rimco 714 259-1385 they'll take care of you for less then $40 bucks! PS don't waste you time trying to fix it yourself I tried all that.
About Fifth Wheel Group
