drfife
Feb 07, 2016Explorer
Halmfamily wrote:
Coach-man, your water filter is designed only to remove particles from the water, there is no charcoal or any other device to remove chlorine or change the taste of the water. By putting the chlorine into the filter it will not make to the water tank. The filter is after the pump. You will only get chlorine into you water lines doing it this way.
Depends on the plumbing.
On my 5th wheel, water flows through the onboard water filter before entering the fresh water holding tank.
Also, I run a charcoal filter in my onboard water filter. It will remove some of the chlorine. I bypass the charcoal water filter when filling my fresh tank.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
